Regular Contributor II
Client info on Instant APs
Finally getting around to testing my IAP units.   We wanted to test 802.11ac, and have deployed an AP-225.
How can I see if the clients are connecting at AC, or some other rate?  I see the type is AN, but I guess they want to know if they are connecting at full AC so they can test the throughput and range.
Re: Client info on Instant APs
Show ap association from the CLI.
Tim Cappalli | Aruba Security
Moderator
In the WebUI you can expand the Clients pane:
Same box but expanded so you can actually see what I was referring to...
And here is the "show ap association" command Cappalli pointed out.   The client I circled above is the same client below and is a Galaxy S4.  The nice thing about "show ap association" is you can see the number of Spatial Streams of the client.
Expanded....
