Client names not showing up on my Virtual Controller
I am having a small issue with my production network. I am using 2 IAP-225's and have configured properly working wireless access, however, on my virtual controller, all my clients have a "--" as there name.  I also set up a demo lab within our private network with an IAP-105 and an IAP-115 and when clients connect, their device name shows up. Please let me know if anyone has a solution or has encountered something similar. I've included a screen shot. Thanks
Occasional Contributor I
Re: Client names not showing up on my Virtual Controller
Has anyone come up with an answer for this one?
Yes! I forgot to answer the questions when I figured out my problem. I updated to the newest AOS version and it solved the issue. HTH
Best Regards,
Sean
Thanks, I thought I had already done this but hadnt.  Solved the issue.
Thanks again
