Cluster management by controller
Greetings dear colleges,
Have plans to make such schema: few Instant clusters connected to controller as a RAP.
Who knows what function will be possible to managed from the the controller on the cluster?
Thanks in advance
Re: Claster management by controller
You would manage the Instants via AirWave or Central. The controller simply handles the VPN tunnel termination and policy enforcement for tunneled traffic.
Tim Cappalli | Aruba Security
so as i understend all claster function could be managed from the controller as a single point of managemetn?!
Super Contributor I
Re: Cluster management by controller
No. The controller would only control the traffic that would traverse a VPN they terminates on it. All other settings must be controlled at the virtual controller on the IAP or via Airwave.
ACDX #419 | ACMP |
No, you can manage the configuration locally on the instant vc, AirWave, or Central.
thanks for your help.
Looks like it's absolutely the opposite to the opinion of tsd25108
