Configure Aruba IAP 103 as Wireless Router
Dear Leads,
I have a Aruba AP 103 (Instant) i need to use that as a Wireless Router, can you please guide me.
Awnish.
Re: Configure Aruba IAP 103 as Wireless Router
Any SSID that you should create should have a Virtual Controller assigned designation, so that all the client traffic will be natted out of the ip address that the IAP receives from the cable modem or router it is plugged into.
Contributor II
What do you mean by wireless router? Connect the IAP wireless as a client to a isp? And connect the lan on the wired port?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
