- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
05-21-2015 01:02 AM
I'm interested in doing some test with Instant AP 224 and I would know if there is some way to enable and disable only specific MCS (for example only allow MCS9) for test purpose.
Also if we can also fix the channel bandwidth (for example only working with 40 or 80 Mhz channels).
Thank you
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Configuring MCS0-9 on Instant AP 224
05-21-2015 03:15 AM
Configuring the MCS rates is not possible on instant. Configuring channel width, is supported. It is called "Wide Channel Bands" for 40mhz configuration and "80 mhz support" for 80 mhz channels in the ARM profile: http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/ARM/Configuring_ARM-Features.htm
Colin Joseph
Aruba Customer Engineering
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-21-2015 03:56 AM
OK,
Is it possible con enable/disable MCSx on campus AP 224?
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-21-2015 12:35 PM
Yes, it is possible on ArubaOS (controller-based). You can configure this under the relevant HT SSID Profile, which is connected to the relevant SSID-profile.
"Supported MCS set" for 802.11n
"VHT - Supported MCS map" for 802.11ac
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-22-2015 12:20 AM
Thank you for your answers,
So, in case of using Instant AP OS on AP 224, are all MCSx available to use by default?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-22-2015 02:11 AM
Yes. That is the standard.
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-22-2015 02:13 AM
Colin Joseph
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
