Occasional Contributor I
Controller AP to IAP
Hi All,
Would it be possible to convert a controller 305 AP (purchased as controller based) to instant?
Thanks!
Re: Controller AP to IAP
It is not possible, unfortunately.
rzz
Contributor II
no that will not be possible
 ok, thanks that is all I needed to know. a bit unfortunal indeed.
