Regular Contributor II
Controller
I have a Aruba 3600 controller.
there is two vlan.
vlan1= 172.16.0.0 network
vlan2= 172.18.0.0 network.
controller is on vlan 1 [controller ip =172.16.0.254]
from controller i am not able to ping any device on vlan2 & from any device in vlan2 i cant able to any device on vlan1 [controller also]
please tell me what i have to do?
i want that they can able to ping each other.
Re: Controller
there is two vlan.
The devices on VLAN2 and VLAN1 must have the controller ip on those VLANs as their default gateway.
Super Contributor I
Re: Controller
You also need to make sure you don't have deny inter user bridging enabled.
ACDX #419 | ACMP |
