Contributor I
Conversion of IAP-105 in Europe to US controller
Quick question hopefully.
I have an IAP-105 in Europe that is trying to be converted to a campus AP on a controller in the US.  Is there regulations that is preventing this IAP from being converted?  If fails during the attempts.
Thanks in advance.
Valued Contributor I
Re: Conversion of IAP-105 in Europe to US controller
To convert an IAP to controller based the Regulatory Domains between the IAP and controller must match:
- An Unrestricted IAP (AKA ROW) such as the IAP-105 cannot connect to a -US controller.
- Similarly, a -US IAP cannot connect to an Unrestricted / ROW controller.
- A -US IAP can connect to a -US controller.
- The same is true for IAP's with the -JP or -IL designations.....they can only connect to -JP or -IL controllers.
- A Unrestricted / ROW IAP can connect to an Unrestricted / ROW controller.
Contributor I
Thanks for the feedback and the valuable information.  From dealing with first line support its like hit or miss and I never did get a straight answer.
