Convert IAP to RAP problem
 I am running ArubaOS version 6.2.1.4 on my Aruba 6000 controller. When I try to convert an IAP to a RAP using the webUI I receive the following error message on the controller when I do a "show log security"
Oct 10 08:18:19 :133006:  <ERRS> |localdb|  User d8:c7:c8:c8:04:fc Failed Authentication
Oct 10 08:18:40 :133019:  <ERRS> |localdb|  User d8:c7:c8:c8:04:fc was not found in the d
atabase
Can anyone let me know what I am doing wrong?
Aruba
Re: Convert IAP to RAP problem
Have you white listed the particular RAP in the RAP-WHITElist on this controller ?
If yes, double check the MAC addr.
JF
I have not that. How do I get to the RAP-Whitelist? Is it under Security>Authentication?
Aruba
Navigate to
Configuration / AP Installation and you should see "RAP White-list"  or "White-list RAP"
JF
Aruba
..and a screenshot to help out
JF
Thanks a million! This was my first RAP!
Aruba
Here to help anytime.
RAPs are great ... lots of fun ;)  and fantastic solution for remote site/teleworker.
JF
