Frequent Contributor II
Converting IAP 105 to a AP 105
Can someone tell me how to do this?
Re: Converting IAP 105 to a AP 105
Sure!  You login to the Instant UI:
1. Click on Maintenance in the top right
2. Click on the Convert Tab
3. Click on the selection to convert to a CAP (Campus AP)
4. Enter the IP address of the controller you wish to terminate to
That's it!  If you'd like to convert BACK to an IAP, then simply issue a hardware reset (paperclip on the bottom of the unit).
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Perfect. Thank you
Regular Contributor II
Hi Guys
I tried that to conver an IAP 105 to CAP and says status not available and no conversion occurs.
Do you know why?
Regards
Super Contributor II
Make sure that IAP and controller both have same regulatory domain.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Contributor I
Hi..
i'm trying to convert IAP to campus ,, but it dosen't work !
i connect IAP dircetly to (PoE) network and when i press vonvert not it says (status not available)
plz help me
I think this is related with image versions...
In order to convert an IAP to RAP, Controller should have minimum 6.1 Image version and also there is a minimum 4.1 IAP version
Regards
Make sure the IAP can communicate with the controller. SSH to the IAP and try pinging the controller.
Zach Jennings
Contributor I
thanks alot
Contributor I
