MVP
DHCP Option 60 and 43 settings in an Adtran DHCP serving switch
I think I have Option 60 ironed out, since the iAP is getting option 43 data.
I clearly have some work to do on the syntax for option 43.
Here's the outpup of "show dhcpc-opts"
*** 8/8/2013 18:02:37 PM    Target: 24:de:c6:c2:d4:e0    Command: show dhcpc-opts ***
-------------------DHCP option43 --------------------
017-wc1, Stores:017, 10.21.0.61, 12345
and the corresponding lines in the Adtran DHCP configuration:
ip dhcp-server pool "Management"
  network 10.22.140.192 255.255.255.192
  default-router 10.22.140.193
  lease 0 1 0
  option 60 ascii ArubaInstantAP
  option 43 ascii "017-wc1, Stores:017, 10.21.0.61, 12345"
 Any thoughts?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Valued Contributor I
Re: DHCP Option 60 and 43 settings in an Adtran DHCP serving switch
The syntax should look like this:
folder1:folder2,AirWave IP,shared secret
Use colons to separate folders/sub-folders for Airwave then use commas.  Be sure there are no spaces anywhere.
Try:
Stores:017,10.21.0.61,12345
MVP
Took a few days to get to test it, but I've made the change in the DHCP server, and did a "show dhcpc-opts"
output here:
It's been up for 10 minutes or so, and it just checked in.
Thanks!
--Matthew
