DNS problem? Maybe?
I have a problem that's driving me nuts!
I cannot get to this web site: https://instantalert.honeywell.com
I can't ping it, Traceroute either just hangs or returns all asterisks.
I have a bunch of IAP-105s. Was running the latest firmware, and even went back to 3.4 to see if that was the issue. Nope. And its the ONLY site I can't get to. I can get to everything else I've tried. Tried several different computers, different access points, turned OpenDNS on and off, still no love.
This only happens going through the WiFi. I can stick a cable in my Macbook and hit that site through the wired network, no problem. And of course, that site is important to us!
I'm thinking its gotta be a setting in Aruba Instant somewhere. HELP!
Glen
Aruba
Re: DNS problem? Maybe?
What are your DNS settings on instant and can you share the config?  I just tried it on a IAP 105 running 4.0.0.4 and it seems to be fine...
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Ok, I figured it out.
Its the "content filter" checkbox on the SSID configuration. If I uncheck it, I can get to the site. No idea why.
Aruba
This is because when it's enabled...all DNS requests are sent to OpenDNS if so configured:
Seth R. Fiermonti
Email: seth@hpe.com
Then why can I hit the site through the wired network, which also goes through OpenDNS?
Aruba
Have you set up the virtual controller with your OpenDNS settings and configured the enterprise domain?
Seth R. Fiermonti
Email: seth@hpe.com
It has our ID and password configured. I guess I don?t know how to configure the enterprise domain.
