Super Contributor I
Deploying Instants with a wifi uplink
All,
I'm currently working with a customer that has a couple of dozen RAPs out in the field. We have the Activate + ClearPass integration and it's going real well.
The one thing that came up during this rollout is that a couple of people are just not able to place the RAP near their home Internet connection. One of the workarounds that I'm currently testing is the following:
1. IAP-109 in Instant mode running 4.1.1.7 code
2. Setup the IAP in the IAP-VPN configuration to tunnel back to the controller in a L3, Distributed manner
3. Set the wifi uplink on a per-user basis.
4. Save the configuration file and copy and paste it into these one-off configs, as needed.
The question I had, is this the best way to go about this type of deployment? Has anyone had success rolling out a larger set of IAPs with the wifi uplink enabled?
Thanks for your time!
-Mike
Valued Contributor II
Re: Deploying Instants with a wifi uplink
HI,
Plan looks good, but why only Distributed L3 ? I believe Distributed L2 is more suitable and stable.
More over, WiFi uplink work fine with any IAP (RAP) but depends on the WIFI service providing device.
Cheers,
Venu Puduchery,
Super Contributor I
Hi Venu,
I have the most experience with L3, Distributed, but I'll give the L2, Distributed a try, too. It looks like that configuration give the user the most "RAP"-like experience. Is that your take on it, too?
In terms of the wifi, I'm just not sure you can program the wifi uplink on anything but a case-by-case basis. It would be great if the user could be prompted with a generic page when they first log in to enter their wifi credentials - similar to how one sets up a phone. I don't think that's an available option, though. Granted, it would be something like the "Hotel Connect" feature of the RAPs that used to be touted by Aruba.
-Mike
