Occasional Contributor I
Devices missing by setting up APs to AirWave
in my company we have 9 APs, managed by the Aruba Instant Controller. Now i wanted to set up all APs to the Aruba Airwave Server. The Problem: Only the Virtual Controler, and one Accesspoint (Master) is added to the Accesspoint group in AirWave. So the other 8 APs are missing in the Overview...
Is there annother nescessary option, to add them to the AirWave Server?
Thanks!
Re: Devices missing by setting up APs to AirWave
when you add VC/controller, default all the assoicated APs will disovered automatically and show up in new devices list in Airwave. We need to manually acknowledge those APs.
Pavan
if my post address your query , give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
The Solution was a new License. I close the call now
