Difference between controller-less Instant APs and controller-based APs
Hi guys,
I would like to know the main differences/advantages of the controller-based APs upon the controller-less flavour of Instant APs. Do they have more features? Do they  provide better performance? If I have a good WLAN with controller-less APs, why should I consider to move to a controller-based AP architecture?
Julián
Re: Difference between controller-less Instant APs and controller-based APs
Hey, take a look at the below forum post. It has been discussed quite a bit at length. Any other questions, just go ahead and ask :)
https://community.arubanetworks.com/t5/Wireless-Access/Controller-vs-IAP/m-p/67732
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
