Difference between voice , guest and employee VLAN/SSID
  • 1.  Difference between voice , guest and employee VLAN/SSID
    Posted Feb 22, 2016 10:45 PM
    Is there any   Difference  between  voice , guest and  employee VLAN/SSID for example  are there any restriction in  this  can we use captive  portal only  for  guest  ??
  • 2.  RE: Difference between voice , guest and employee VLAN/SSID
    Posted Feb 22, 2016 11:04 PM
    They have optimizations and settings for each scenario.
    Sent from Nine
