Frequent Contributor II
Different between IAP and AP
How is different features between IAP and AP or
Do you have some materials for compare feature ?
And i want to know when i want to use AIRWAVE integrate with IAP, AIRWAVE is software or hardware and how i install airwave
Thank you
Re: Different between IAP and AP
iap is a controller less platform and APs require a dedicated controller.
airwave is a software that can be installed on a dedicated server, VM or you can purchase the Airwave appliance
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
and how about feature ?
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Need-Ins
tant-vs-Controller-Advice/m-p/124829
Tim Cappalli | Aruba Security
