Disabling legacy client devices
In IAP225, I would like to block legacy clients connecting to the SSID's. The arubas document suggests to use 'legacy-mode' command to control the legacy clients. As per the document, all non 802.11n devices are considered as 'legacy devices'. The document description is as given below.
legacy-mode - Enables the IAPs to run the radio in non-802.11n mode.
According to the above description, when disabled, any 802.11 a/b/g devices should NOT be able to connect to the network however it does not seem working. Please have a look at the below logs:
  IAP225# show radio config
  2.4 GHz:
  Legacy Mode:disable
  Single Chain Legacy:disable
  Beacon Interval:100
  802.11d/802.11h:enable
  Interference Immunity Level:2
  Channel Switch Announcement Count:0
  MAX Distance:600
  Channel Reuse Type:disable
  Channel Reuse Threshold:0
  Background Spectrum Monitor:disable
  Max Tx Power:0
  Min Tx Power:0
  5.0 GHz:
  Legacy Mode:disable
  Beacon Interval:90
  MAX Distance:600
  Standalone Spectrum Band:5ghz-upper
  Max Tx Power:0
  Min Tx Power:0
  IAP225#
Connected Clients:
IAP225# show ap association
The phy column shows client's operational capabilities for current association
Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz; t: turbo-rates (256-QAM)
             VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
             <n>ss: <n> spatial streams
Association Table
Name               bssid              mac                auth  assoc  aid  l-int  essid          vlan-id  tunnel-id  phy              assoc. time  num assoc  Flags  DataReady
18:64:72:c8:51:56  18:64:72:05:15:72  cc:fa:00:a9:12:9a  y     y      1    10     Q_streaming_1  4092     0x0        a-VHT-20sgi-1ss  1m:30s       1          W      Yes (Implicit)
18:64:72:c8:51:56  18:64:72:05:15:72  c8:f9:f9:34:13:8e  y     y      2    12457  Q_streaming_1  4092     0x0        a                52s          1                 Yes (Implicit)
18:64:72:c8:51:56  18:64:72:05:15:63  5c:50:15:24:f0:21  y     y      2    12457  Q_streaming_2  4092     0x0        g                1m:16s       1                 Yes (Implicit)
18:64:72:c8:51:56  18:64:72:05:15:63  18:af:61:68:e0:f8  y     y      1    20     Q_streaming_2  4092     0x0        g-HT-20sgi-1ss   20s          1          WK     Yes (Implicit)
Num Clients:4
IAP225#
Question: Is 802.11b device only considered as legacy device[a/g are not]? It could be  a case that information  documents is not correct. Need clarification on this.
        or
controlling the legacy devices functionality not working in IAP225?
Please let me know.
Shiva
Re: Disabling legacy client devices
You cannot currently disallow 11a and 11g clients from associating. You can however remove the data and basic rates under 12 to stop 11b clients from associating.
Tim Cappalli | Aruba Security
Thank you for your quick response. I will change the data rate and test again.
Shiva
