Disabling radio in IAP
Hi
can anyone tell me how to disable the radio interface in IAP?
if it is possible to disable, then it can be done via ov3600?
Re: Disabling radio in IAP
You can make it an airmonitor
Thank you
Victor Fabian
Lead Mobility Architect @WEI
