Does IAP-205 with 6.4.2.6-4.1.1.6 support mesh point?
I have set up a few IAP-205. After I disconnected one IAP-205 from the switch, it couldn't become a mesh point. Mesh Role on Access point list shows N/A. Does IAP-205 with 6.4.2.6-4.1.1.6 support mesh point?
Thanks.
Re: Does IAP-205 with 6.4.2.6-4.1.1.6 support mesh point?
It is supported starting on  6.4.3.1-4.2
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I have ugraded to 6.4.2.6-4.1.1.11-52666. Build Time is 2015-11-22. It shows "No new version available" when I clicked on Check for Update from Maintenance -> Firmware. Where should I get the new firmware?
Thanks.
That version is not in the Cloud server because is an Early Release version
Thank you
Victor Fabian
if you have a support account you would be able to download the early version.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
