Frequent Contributor I
Does IAP comes with OpenSSL/TLS feature?
Does IAP (IAP-105) comes with OpenSSL/TLS feature?
No, right?
Thus, it is not affected by OpenSSL vlunerabilities, right?
"If there's a will, there's a way."
Re: Does IAP comes with OpenSSL/TLS feature?
It is not affected by the latest vulnerabilities.
http://www.arubanetworks.com/support/alerts/aid-08182014.txt
ACCP, ACCX #817, ACMP, ACMX #294
Thanks, Michael!
Does IAP support any other form of TLS implementation (other than OpenSSL)?
Trusted Contributor I
i don't believe so, to be honest i don't know any product that can just change the whole SSL implementation with a configuration flag or such.
