Contributor I
Does IAP need to be the DHCP server in order for roaming to work?
We just purchased a couple of IAP-225 and am going over the manaul before setting it all up. I noticed that in the section for "Virtual Controller" it mentions ". It also acts as a node, coordinating DHCP address allocation for network address translated clients ensuring mobility of the clients when they roam between different IAPs." Does that mean that the IAP has to be the DHCP server for roaming to work or can I continue using my own DHCP server?
Valued Contributor I
Re: Does IAP need to be the DHCP server in order for roaming to work?
It means that the IAP can be a DHCP server but it does not have to be.   When you are creating an SSID you are presented with an option for IP Assignment.  You can choose "Virtual Controller assigned" or "Network Assigned".  Roaming should be seamless regardless of the source of DHCP.
Super Contributor II
What it means by coordinating DHCP address allocation etc is that the VC, if issuing DHCP addresses will replicate this to the other devices. If the device that is currently holding the VC role fails, the device that takes ownership of the VC address will have all the DHCP and NAT'ing info to ensure a smooth transition for clients.
