Frequent Contributor I
Does "clear os" no longer work in Instant?
I've has three different times now since 3.3 has come out where I attempted to the clear the OS from the CLI on different APs with no luck.
The AP boots back up with the old config.
Has this changed?
> clear os
> purgeenv
> saveenv
>reset
EDDIE FORERO | @HeyEddie
Re: Does "clear os" no longer work in Instant?
Do you have it plugged in the same segment/VLAN as the other configured IAPs?
Thank you
Victor Fabian
Lead Mobility Architect
No. No existing IAPs.
And I've had this happen recently in our lab.
You may have already tried this but just in case , check this link:
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1417
Thank you
Victor Fabian
