EIRP / Conducted power IAP's
Hello there ,
is there a way to see the EIRP / antenna gain / conducted power for an IAP similar to a controller based AP using
show ap debug driver-log ap-name (xxx) | include EIRP
I am using IAP93 and IAP105 6.2.0.0 or later.
id like to get a similar output to below
594    765882.908704 wifi0: EIRP (Config: 18.0dBm, Set: 18.0dBm, AP Max: 26.0dBm, Reg Max: 23dBm), Conducted Power Set: 12.0dBm, Gain: 6.0dBm
599    769044.918390 wifi1: EIRP (Config: 18.0dBm, Set: 18.0dBm, AP Max: 25.5dBm, Reg Max: 20dBm), Conducted Power Set: 12.5dBm, Gain: 5.5dBm
but i cant find a CLI or GUI command to give me that information.
I have tried ap tech support dumps and show ap driver-config, show log driver
Im sure it must be possible.
Any help appricated.
Aruba
Re: EIRP / Conducted power IAP's
does:
show ap bss-table
show ap debug driver-config
Help you at all?
| Adam Kennedy, Systems Engineer - adamk@hpe.com
| Service Providers – Aruba, an HPE Company
| Twitter: @adam8021x | Airheads: akennedy
