Occasional Contributor I
ERR_IKE_TIMEOUT errors from APs - No VPNs configured
I have a small cluster (3) AP-109s running Instant 6.5.4.3_61959. It is working as configured.
I do not have cluster security enabled.
I do not have any VPNs enabled.
My WLAN is 192.168.23.0/24
My syslog server is receiving the following two errors from all of my APs every several seconds:
cli[xxxx]: [primary tunnel] Error!!!: Received RC_OPCODE_ERROR lms192.168.10.2 tunnel 0.0.0.0 RC_EROR_IKEP2_PKT1 debug-error:-8949 (ERR_IKE_TIMEOUT)
cli[xxxx]: [primary tunnel] tunnel_err_msg_recv(1762): Error !!! Received RC_OPCODE_ERROR peer public ip 192.168.10.2 tunnel ip 0.0.0.0, controller ip 0.0.0.0, RC_EROR_IKEP2_PKT1 debug-error:-8949 (ERR_IKE_TIMEOUT)
These errors looked like crypto failures that are VPN related, but I do not have a VPN configured.  Also I have no idea where the IP address 192.168.10.2 was coming from (where it had been configured).  It is not in my current configuration
I decided to do a show vpn status from the cli and I found the 192.168.10.2 IP address; it is defined as the primary tunnel peer address!  See below:
AP109-East# show vpn status
profile name:default
current using tunnel                            :unselected tunnel
current tunnel using time                       :0
ipsec is preempt status                         :disable
ipsec is fast failover status                   :disable
ipsec hold on period                            :600s
ipsec tunnel monitor frequency (seconds/packet) :5
ipsec tunnel monitor timeout by lost packet cnt :6
ipsec     primary tunnel crypto type            :Cert
ipsec     primary tunnel peer address           :192.168.10.2
ipsec     primary tunnel peer tunnel ip         :0.0.0.0
ipsec     primary tunnel ap tunnel ip           :0.0.0.0
ipsec     primary tunnel using interface        :
ipsec     primary tunnel using MTU              :0
ipsec     primary tunnel current sm status      :Retrying
ipsec     primary tunnel tunnel status          :Down
ipsec     primary tunnel tunnel retry times     :404
ipsec     primary tunnel tunnel uptime          :0
ipsec      backup tunnel crypto type            :Cert
ipsec      backup tunnel peer address           :N/A
ipsec      backup tunnel peer tunnel ip         :N/A
ipsec      backup tunnel ap tunnel ip           :N/A
ipsec      backup tunnel using interface        :N/A
ipsec      backup tunnel using MTU              :N/A
ipsec      backup tunnel current sm status      :Init
ipsec      backup tunnel tunnel status          :Down
ipsec      backup tunnel tunnel retry times     :0
ipsec      backup tunnel tunnel uptime          :0
AP109-East#
So my questions are why are my APs trying to establish a VPN tunnel with a controller when it is not configured?  All my APs are associated with my virtual controller
And how to I reconfigure my APs in order to stop the constant barrage of log messages.
Re: ERR_IKE_TIMEOUT errors from APs - No VPNs configured
Are you sure you don't have anything under the More> VPN listing?
Positive nothing under More->VPN.
Just Aruba IPSec in the drop down and primary & backup host fields are blank.
More info:
I did a fill reset of my AP by booting into the APBOOT mode and doing a factory_reset, clearOS and then a save.  I booted up the AP and upgraded the os to Instant 6.5.4.3 and rebooted. Then I manually reconfigured it by assing the SSID, the virtual controller info and set the IP address of the syslog server.   I tested the configuration to validate it and backed up the config.  I shut down the AP and did a paperclip reset of the AP.  When it booted, I restored the saved config and rebooted again.
Within several seconds of the AP booting up, I see the following in my syslog file:
<WARN> <192.168.23.81 24:DE:C6:CB:60:22> provision try
<WARN> <192.168.23.81 24:DE:C6:CB:60:22> provision recv_convert_ap: Convert AP Url- mode-1, master-192.168.10.2
<WARN> <192.168.23.81 24:DE:C6:CB:60:22> Setup VPN for RAP conversion - 192.168.10.2
<WARN> <192.168.23.81 24:DE:C6:CB:60:22> Set amp discover allowed: code: success
The the previous error message pair started showing up every few seconds.
Why is my AP trying to do a a conversion when it is the virtual controller?
It almost looks like you have a convert rule in activate.  I would contact TAC, if you could.  Activate is a cloud service that the IAP contacts on first boot, and you could have a convert to CAP or Convert to RAP rule in activate that you are hitting...
Colin,
Thanks for the reply. Were would that rule originate from?  Is that a setting in the APBOOT environment variables?
No.    Register for an account here:  https://activate.arubanetworks.com/registration/
When you get a login to activate, add your device using the cloud activation key. You can find the key like this: http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-find-the-cloud-activation-key-via-CLI/ta-p/234889
That might solve your issue.
Do you have a controller on your network that the AP might be reaching out to?
Also, is this a new IAP or used?
