Occasional Contributor I
Enable ACM for voice on 7210 with 6.5.4.1 OS
my controller model is 7210 and OS is 6.5.4.1
i am unable to find options or CLI commands to enable ACM for voice.
Documents reffered points to SSID profile.
But SSID profile prompts only options to enable WMM and not ACM.
Can anyone please help on this at the earliest.
Re: Enable ACM for voice on 7210 with 6.5.4.1 OS
Are you looking for information on Call Admission Control (CAC)?
More info may be found here:
http://www.arubanetworks.com/techdocs/ArubaOS_651x_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Voice_Video/QoS_for_Voice_and_Video.htm?Highlight=CAC
Charlie Clemmer
Aruba Customer Engineering
Thanks allot for your response.
i had gone through this doc.
But the EDCA profile configuration is found in either CLI or UI of the SSID
profile.
Aparna Ramakrishna
 Hi Aparna,
ACM values can be defined in the EDCA profile. This profile in turn gets mapped to SSID profile.
(Aruba) (config) #wlan edca-parameters-profile ?
ap Configure an EDCA Parameters profile (AP)
station Configure an EDCA Parameters profile (Station)
(Aruba) (config) #wlan edca-parameters-profile ap ?
<profile-name> Profile name
(Aruba) (config) #wlan edca-parameters-profile ap test
(Aruba) (EDCA Parameters profile (AP) "test") #voice ?
acm Admission control mandatory
aifsn Arbitrary inter-frame space number
ecw-max Maximum contention window (exponent)
ecw-min Minimum contention window (exponent)
txop Transmission Opportunity slots in 32 usec units
<cr>
(Aruba) (EDCA Parameters profile (AP) "test") #voice acm ?
0-1 0 to disable ACM; 1 to enable ACM
Where do I create an edca profile???
Or can I run this command on ap profile???
Aparna
Hi Aparna,
EDCA profiles can be created for both AP & clients in order to ensure traffic is priortized both ways.
Please download the UG using the below link:
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=23154
It contains the steps to configure profile using both WebUI & CLI.
