Occasional Contributor I
Exclude range in Instant DHCP
Is it possible to exclude an IP range of 172.31.99.180 and above from the Instant default DHCP Pool
Re: Exclude range in Instant DHCP
From playing around with an IAP, there does seem to be a way around it, but it seems a bit odd to do it this way.
1. Click on System--Show Advanced Options and click on DHCP.
  • Select a different range than what is the default 172.31.98.0/23
2. Click on More--DHCP Server
  • Add an "Other" scope and select the type “Local”
  • Choose a VLAN for this scope
  • Use the 172.31.98.0/23 subnet
  • Exclude 172.31.99.180 (everything above this IP will be excluded)
  • Fill in the other fields as needed
3. Change the SSIDs to be statically set to this VLAN
  • Edit the SSID and change it from "Virtual Controller Assigned" to "Network Assigned"
  • Select a Static VLAN, and use the VLAN number created for the scope in step 2
