Feature comparison between IAP and CAP
Hello
I'm searching for a comparison between instant and campus AP. I've found alot of old topics with this question, but no real overview about the features. As far as I know the IAP does not support all features that the CAP with wireless controller supports. Is there a chart or list that shows the differences?
Thanks in advance
Re: Feature comparison between IAP and CAP
Hey, as far as I know there is no official comparison chart to list the differences between a controller based and controllerless architecture. With every release there is a an increase in feature set on the IAP which does reduce the feature set gap between controller vs controller less.
Was there a particular feature you was interested in?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
