Firmware
We are using aruba IAP 225 in our organisation. Let us assume that IAP 225 running on 4.3.2-6.3.2-4.302 and after so many patches are released.But latest firmware is 5.6.3.0.
Should i upgrade directly to 5.6.3.0 or i should go with all patches.
Re: Firmware
You should stay on the version of Instant that you are on, unless you need to possibly have a bug fixed or you need a feature.  There is no advantage to upgrading otherwise.
Re: Firmware
Hi this is sandeep...
Actually i need to upgrade coz of few applications are not supporting on existing firmware. My doubt is should i upgrade directly to new release or i should go patches wise
