Flat wall mounts for IAP-205-US
Hi everybody,
I'm looking for a flat wall mount for an IAP-205.  In the IAP-205's datasheet, I've found these 2 wall mounts:
AP-200-MNT-W2
AP-220-MNT-W1
The AP-220-MNT-W1 is exactly the kind of mount I'm looking for, but when I look either of those up in various distribution channels, they both don't state compatibility with the IAP-20x series.
Has anybody else used the AP-220-MNT-W1 with an IAP-205, or have definitive information that the two are compatible?
Re: Flat wall mounts for IAP-205-US
The W1s will work with all 3 200 variants.
Tim
Tim Cappalli | Aruba Security
Thank you, Tim!
For any others who might be wondering, I'll reply if I encounter any issues or oddities.
