Force SSID for specific operating system
  • 1.  Force SSID for specific operating system
    Posted Oct 10, 2018 02:52 AM
    Hi community,
    do you know if its possible to restric access to only one SSID for a specific operating system ?
    An exemple : Android devices can only connect/view SSID "guest".
    Thanks for your help
    Alexis
  • 2.  RE: Force SSID for specific operating system
    Posted Oct 10, 2018 05:18 AM
    You can do some blocking of devices by doing DHCP fingerprinting, but you cannot force devices to connect to an SSID based on operating system.
  • 3.  RE: Force SSID for specific operating system
    Posted Oct 10, 2018 05:29 AM
    Ok thanks !
    Do you know if there is an Aruba service that can do this kind of function ?
    Alexis
  • 4.  RE: Force SSID for specific operating system
