Hi all,
i want to configure GRE tunnel between AOS6900 and ArubaOS 6.4
I have configuration as below. Although i create an ip tunnel on Aruba. But i ping it failed.
is my configuration correct?
Thanks all :)
on Aruba:
(OAW-4604) #show ip interface brief
Interface IP Address / IP Netmask Admin Protocol
vlan 999 172.16.92.7 / 255.255.255.0 up up
vlan 1 unassigned / unassigned up up
vlan 100 100.1.1.7 / 255.255.255.0 up up
vlan 1001 192.168.1.246 / 255.255.255.0 up up
loopback unassigned / unassigned up up
mgmt unassigned / unassigned down down
tunnel 1 88.88.88.2 / 255.0.0.0 up up
(OAW-4604) #show interface tunnel 1
Tunnel 1 is up line protocol is up
Description: Tunnel interface
Internet address is 88.88.88.2 255.0.0.0
Source 192.168.1.246
Destination 192.168.0.25
Tunnel mtu is set to 1500
Tunnel is an IP GRE TUNNEL
Tunnel is Trusted
Inter Tunnel Flooding is enabled
Tunnel keepalive is disabled
Keepalive type is Default
(OAW-4604) #ping 192.168.0.25
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 192.168.0.25, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.439/0.5234/0.686 m
s
i cannot ping its ip tunnel
(OAW-4604) #ping 88.88.88.2
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 88.88.88.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
(OAW-4604) #ping 88.88.88.1
Press 'q' to abort.
Sending 5, 100-byte ICMP Echos to 88.88.88.1, timeout is 2 seconds:
(OAW-4604) #
