Guest SSID with PSK and Role based bandwidth contract
Hi I am trying to setup my Guest SSID with a splash screen, with this I would like to trottle back the bandwidth of the users to 2 mbps up and downstream.
when I set the PSK on the security tab and then set the 2mbps on the access tab and add a rule under bandwidth contract.  All the settings wont save the role based/bandwith rule gowes back to unrestricted.
Am I missing something
Thanks for the replies
Re: Guest SSID with PSK and Role based bandwidth contract
EDIT:  Instant AP
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
  1. So I goto Configuration> Access Control there is no user roles just unrestricted, Network based and role based. I went into role based and set the bandwidth but it wont keep the setting if I have encryption enabled, when I go back to Access it is back at unrestricted
We created a new user role called guest and then under the Bandwidth Contracts tab we set bandwidth limits.  Hope this helps
  • OK we dont have an enforcement license installed
If I got to WLAN setting and advanced options there is an area for bandwidth Limits do I need the enforcement License for that and will that give me what I need
I just tested it on IAP running 6.5.4.4. Yes the knob goes back to unrestricted, however if you move it back to Role based, & click on the role, you would see the bandwidth contract in place.
If you SSH into IAP and do a show run, you can see something like:
wlan access-rule "SSID1"
index 3
rule any any match any any any permit
bandwidth-limit downstream 4
bandwidth-limit upstream 2
So definitely the config is getting saved, atleast on the latest version.
But why did the slider move back to unrestricted?
I will get a bug filed for it.
Yes it is there, thank you
  •  rule any any match any any any permit
     bandwidth-limit peruser downstream 2048
     bandwidth-limit peruser upstream 2048
