MVP
Guest wireless support a wires interface?
I have a guest wireless SSID set up and it happily tunnels users back to my Aruba-3600 controller at HQ where I drop off on our ISP.
Works great for CAP guests, and for iAP guests.
Locally I've been able to put wired guests on the same VLAN and they get access to the internet through the controller (no portal since I "trust" the vlan at the controller)
Would it be possible to connect a wires user to my switch-fabric and put her in the same VLAN as the Guest SSID and have the iAP 105 tunnel that VLAN back?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Aruba
Re: Guest wireless support a wires interface?
I don't see why that wouldn't work.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
