[HELP] Controlling one of SSID's traffic through firewall
Hello there
Iam new to Aruba infact new to this technology . I would like to discuss  the change  I need in the WiFi traffic . There are 11 nos. 215 IAP  on version 6.4.2.6 having 1 SSID as employee  running on network assignned with DHCP being the firewall which have content filtering policy applied on it .
I need to create a new SSID for guest which will be having a different content filtering policy also on firewall .
Now the Question is how can I possibly achieve this ?
Do I have to set up a local L2 DHCP scope for guests so that I can control the traffic through firewall ?
If yes can someone please provide me a guide for setting up local DHCP
OR
Is there any other way through which i can achieve this ?
Thanks In Advance
Re: [HELP] Controlling one of SSID's traffic through firewall
There are many, MANY ways of achieving this. I would recommend reaching out to your local Aruba partner for assistance.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
