HP switchport configuration commands for Instant APs
We are deploying an Aruba Instant cluster in Europe, where the facility is HP switch/route.  Here in the US we are 100% Cisco in that space, so I have no experience configuring an HP switch.  We are setting up multiple VLANs to support AP management, internal production traffic and guest internet access.
The European facility currently has a flat network running on VLAN 1 and has no experience configuring multiple VLANs on HP gear.  What I'm looking for is help converting our Cisco IAP port configuration to an HP port configuration as follows, where VLAN 1 is for AP management, VLAN 618 is production, and VLAN 619 is guest internet:
interface gi1/0/24
 description Aruba AP
 switchport trunk native vlan 1
 switchport trunk allowed vlan 1, 618-619
 switchport mode trunk
exit
Re: HP switchport configuration commands for Instant APs
vlan 1 untagged 24
vlan 618 tagged 24
vlan 619 tagged 24
interface 24
name Aruba AP
Tim Cappalli | Aruba Security
interface gi1/0/24
exit
Welcome to the world of HPE.  Below is a link to a doc that helps you translate between Cisco and HPE switching products:
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=c04793912
Colin Joseph
Aruba Customer Engineering
Spoiler
Thanks Tim & Colin.  I'll bookmark that link, I feel it will be needed down the road, as I believe all of our European facilities are HP switch/route.
