Regular Contributor II
Heads Up - IAP is very unresponsive [ Wired Network]
Hi Folks,
In one of my client place, we are seeing very high latency while pinging IAP's from wired network.
Even we are not able to open GUI or CLI. but wireless network is working fine and IAP's are doing their work perfectly. So from normal users there are no complain, but for network admin this is a headache.
Any ideas ??
Re: Heads Up - IAP is very unresponsive [ Wired Network]
Please open up a support case
Colin Joseph
Aruba Customer Engineering
Sure, I will do that and I will post here when I will get the solution.
Frequent Contributor II
Hi SumaN,
I had a very similar issue with a cluster of IAP-103. I opened a case with Aruba and we solve the issue with a firware upgrade to the latest code (when i had the problem, the IAP had the AOS  6.4.2.3 -4.1.1.2).
Also, in the AP Radio-Profile I had enabled the "spectrum-monitor"; we changed this to "access mode".
I hope this will helpful for you.
Massimo
[If you found my post helpful, please give kudos]
Massimo Gallina
Telecommunications engineer - ACMP2013
Super Contributor I
Yes this sounds like you´re on the early versions of 4.1.1.x. Consider upgrading.
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
I got the issue fixed but still finding the root cause.
The TAC engineer disabled L3 mobility because we are not using that, after that all AP's cpu utilization went to normal.We asked customer for syslog message but he was not agreed to give it so now we are collecting it from Airwave :)
I'm using 6.3.1.8-4.0.0.8 .
how are you using 4.0.0.8? It is not out yet? Is that a beta build you were provided?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
I thought I read 4.1.1.8 not 4.0.0.8...lol...case of the Mondays (on a Wednesday)
ACDX #420 | ACCA
