Contributor I
Help with IAP-VPN setup
I'm trying to configure a RAP3 in an IAP-VPN configuration but I'm having trouble getting my client to get an ip address once the VPN is up.
I have setup the VPN which establishes fine.
I have created a route of 0.0.0.0 0.0.0.0  gateway = public IP of my controller
I have created a DHCP scope as centralized L3 with VLAN = 100
My WLAN is authentication = Open, IP address assigned from network, vlan = 100.  No access restrictions.
When my client tries to connect to the SSID being broadcasted, it is unable to obtain an IP address.
NoteL I have a number of RAPs (running in RAP mode) terminating on the same controller, they land on the same VLAN (100) and they work fine.
Any help would be appreciated
Re: Help with IAP-VPN setup
Can you please post your config in a reply?  If you are on the controller, issue the show iap table command.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Please find the RAP and controller configs attached. Also, see below output form show iap table, I've highlighted my RAP
(uktcnwc3) #show iap table
Branch Key                                             Index     Status     Inner IP        MAC Address             Subnet
5522637801d5a0352a5f9aa56fdce2d66c3ee361316ad2884c     10        UP         2.2.2.157       d8:c7:c8:c7:46:3b
9b528851018450611e02bcccba3eca514876d233200a301666     7         DOWN       0.0.0.0         00:0b:86:83:0b:64
7bf4d682015921198f9fb2c2d9694f66c85acd9405733b2557     4         UP         2.2.2.93        6c:f3:7f:ce:3c:e8
298ea6dd01054e3fbc8c93eeac0e88ebbf934e3c15745d3e36     6         DOWN       0.0.0.0         24:de:c6:c3:44:21
5fdb1d480136333d703517e078adafaa62ac8d86c330466688     1         DOWN       0.0.0.0         00:0b:86:83:0f:06
a7496c14010ead593f6c26fa6b48206f58bf83e92b2252d9bf     8         UP         2.2.2.100       6c:f3:7f:ce:3c:78
b5e7b8b30119cc2be065c727598e52e705c40f2d656a291be7     0         UP         2.2.2.178       00:0b:86:82:89:80
ae5fd86e019a12628350283089fcfdbde6b337a626dc9ec94d     3         UP         2.2.2.91        6c:f3:7f:ce:39:fa
eeeaf6e501837241da77e757b4dc38a76b261418b48e0963e0     5         DOWN       0.0.0.0         6c:f3:7f:ce:3c:14
87c37e2b014a75b349d27a5f68f54b98e62efcec6a0823fb4c     2         DOWN       0.0.0.0         d8:c7:c8:ce:73:92
Contributor I
Doesn't seem to want to attach my controller config, so pasting it in here,
(xxxxnwc3) #show run
Building Configuration...
version 6.2
enable secret "******"
enable bypass
telnet cli
hostname "xxxxnwc3"
clock summer-time CDT recurring last sunday march 02:00 last sunday october 02:00 -5
clock timezone CST -6
location "Building1.floor1"
controller config 8
ip NAT pool dynamic-srcnat 0.0.0.0 0.0.0.0
ip access-list eth validuserethacl
  permit any
netservice svc-pcoip2-tcp tcp 4172
netservice svc-netbios-dgm udp 138
netservice svc-snmp-trap udp 162
netservice svc-https tcp 443
netservice svc-dhcp udp 67 68 alg dhcp
netservice svc-citrix tcp 2598
netservice svc-syslog udp 514
netservice svc-l2tp udp 1701
netservice svc-ike udp 500
netservice svc-smb-tcp tcp 445
netservice svc-ica tcp 1494
netservice svc-pptp tcp 1723
netservice svc-sccp tcp 2000 alg sccp
netservice svc-telnet tcp 23
netservice svc-lpd tcp 515
netservice svc-netbios-ssn tcp 139
netservice svc-sip-tcp tcp 5060
netservice svc-kerberos udp 88
netservice svc-tftp udp 69 alg tftp
netservice svc-pcoip-udp udp 50002
netservice svc-pcoip-tcp tcp 50002
netservice svc-http-proxy3 tcp 8888
netservice svc-noe udp 32512 alg noe
netservice svc-cfgm-tcp tcp 8211
netservice svc-adp udp 8200
netservice svc-pop3 tcp 110
netservice svc-dns udp 53 alg dns
netservice svc-rtsp tcp 554 alg rtsp
netservice svc-msrpc-tcp tcp 135 139
netservice svc-http tcp 80
netservice vnc tcp 5900 5905
netservice svc-h323-udp udp 1718 1719
netservice svc-h323-tcp tcp 1720
netservice svc-vocera udp 5002 alg vocera
netservice svc-http-proxy2 tcp 8080
netservice svc-sip-udp udp 5060
netservice svc-nterm tcp 1026 1028
netservice svc-noe-oxo udp 5000 alg noe
netservice svc-natt udp 4500
netservice svc-ftp tcp 21 alg ftp
netservice svc-microsoft-ds tcp 445
netservice svc-svp 119 alg svp
netservice svc-smtp tcp 25
netservice svc-gre 47
netservice web tcp list "80 443"
netservice svc-netbios-ns udp 137
netservice svc-sips tcp 5061 alg sips
netservice svc-smb-udp udp 445
netservice svc-ipp-tcp tcp 631
netservice svc-esp 50
netservice svc-pcoip2-udp udp 4172
netservice svc-v6-dhcp udp 546 547
netservice svc-snmp udp 161
netservice svc-bootp udp 67 69
netservice svc-msrpc-udp udp 135 139
netservice svc-ntp udp 123
netservice svc-icmp 1
netservice svc-ipp-udp udp 631
netservice svc-ssh tcp 22
netservice svc-v6-icmp 58
netservice svc-http-proxy1 tcp 3128
netservice svc-vmware-rdp tcp 3389
netdestination HOME192_168
  network 192.168.0.0 255.255.0.0
netdestination CORP-NETS
  network 10.0.0.0 255.0.0.0
  network 10.1.0.0 255.255.0.0
  network 205.203.64.0 255.255.224.0
  network 172.16.0.0 255.240.0.0
ip access-list session icmp-acl
  any any svc-icmp  permit
ip access-list session allowall
  any any any  permit
  ipv6  any any any  permit
ip access-list session w19733-split-tunnel
  any any svc-dhcp  permit
  any any svc-dns  permit
  any   alias CORP-NETS any  permit
  any   alias HOME192_168 any  route src-nat
ip access-list session iaprole
  any host 172.18.96.226 any  src-nat
ip access-list session v6-http-acl
  ipv6  any any svc-http  permit
ip access-list session http-acl
ip access-list session dhcp-acl
ip access-list session ap-uplink-acl
  any any udp 68  permit
  any host 224.0.0.251 udp 5353  permit
ip access-list session ap-acl
  any any svc-gre  permit
  any any svc-syslog  permit
  any user svc-snmp  permit
  user any svc-snmp-trap  permit
  user any svc-ntp  permit
  user any svc-ftp  permit
ip access-list session v6-ap-acl
  ipv6  any any svc-gre  permit
  ipv6  any any svc-syslog  permit
  ipv6  any user svc-snmp  permit
  ipv6  user any svc-snmp-trap  permit
  ipv6  user any svc-ntp  permit
  ipv6  user any svc-ftp  permit
ip access-list session v6-logon-control
  ipv6  user any udp 68  deny
  ipv6  any any svc-v6-icmp  permit
  ipv6  any any svc-v6-dhcp  permit
  ipv6  any any svc-dns  permit
ip access-list session h323-acl
  any any svc-h323-tcp  permit queue high
  any any svc-h323-udp  permit queue high
aaa derivation-rules user test
vpn-dialer default-dialer
  ike authentication PRE-SHARE ******
user-role ap-role
 access-list session control
 access-list session v6-control
user-role denyall
user-role default-vpn-role
 access-list session v6-allowall
user-role default-via-role
user-role iaprole
user-role stateful-dot1x
user-role authenticated
user-role logon
 access-list session logon-control
 access-list session captiveportal
 access-list session vpnlogon
 access-list session captiveportal6
controller-ip vlan 96
interface mgmt
        shutdown
vlan 6 "Enterprise_VPN"
vlan 96 "Enterprise_MGMT"
vlan 100 "RAP_User_VLAN"
vlan 500
vlan 999
vlan 1200
vlan 1201
vlan 1202
no spanning-tree
interface gigabitethernet 1/0
        description "GE1/0"
        trusted
        trusted vlan 1-4094
        switchport mode trunk
        switchport trunk native vlan 999
        switchport trunk allowed vlan 96,100,500,999,1200-1202
interface gigabitethernet 1/1
        description "GE1/1"
        shutdown
        trusted vlan 1-4094
interface gigabitethernet 1/2
        description "GE1/2"
        trusted
        trusted vlan 1-4094
        switchport trunk allowed vlan 6,999
interface gigabitethernet 1/3
        description "GE1/3"
        shutdown
        trusted vlan 1-4094
        switchport access vlan 1203
interface vlan 96
        ip address 172.18.96.106 255.255.252.0
interface vlan 1
        shutdown
interface vlan 6
        ip address 213.62.87.102 255.255.255.224
interface vlan 100
        ip address 172.18.100.240 255.255.254.0
        ip helper-address 172.18.96.226
master-redundancy
  master-vrrp 96
  peer-ip-address 172.18.96.107 ipsec 95f55f5a6f3f4c952fe4aef4b07746a7d8928663746e2935
vrrp 66
  priority 120
  ip address 213.62.87.104
  vlan 6
  preempt delay 1
  no shutdown
vrrp 96
  priority 120
  ip address 172.18.96.108
  vlan 96
  no shutdown
ip default-gateway 213.62.87.97
ip route 205.203.64.0 255.255.224.0 172.18.96.254
ip route 10.1.0.0 255.255.0.0 172.18.96.254
ip route 10.0.0.0 255.0.0.0 172.18.96.254
ip route 172.16.0.0 255.240.0.0 172.18.96.254
uplink disable
crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
crypto ipsec transform-set default-aes esp-aes256 esp-sha-hmac
crypto dynamic-map default-dynamicmap 10000
  set transform-set "default-transform" "default-aes"
crypto isakmp eap-passthrough eap-tls
crypto isakmp eap-passthrough eap-peap
crypto isakmp eap-passthrough eap-mschapv2
ip local pool "RAP-Inner-IP-Pool" 1.1.1.1 1.1.1.254
ip local pool "iap-vpn-pool" 2.2.2.1 2.2.2.254
vpdn group l2tp
mgmt-user admin root 8853a8fb01c9c550921b62f464f6ca84e3e92234ef667aeb0a
ip domain lookup
ip domain-name xxx.com
ip name-server 172.18.96.226
country GB
aaa authentication mac "default"
aaa authentication dot1x "default"
   no validate-pmkid
aaa authentication dot1x "global-802.1x auth profile"
aaa authentication-server radius "xxxxndc0"
   host "172.18.96.226"
   key be5605ea8ab56270c06269c07517db341b2f8a0de2b5fdbd
aaa authentication-server radius "ustwndc3"
   host "10.1.32.205"
   key 166e2a04393ae689e86bf1e95958fb3b1e52de76c4b25b28
aaa authentication-server tacacs "ustccsec2"
   host "10.1.96.150"
   key f7949e746c34b577885d0dd3ee9b4e969a88c2733c593a49
aaa authentication-server tacacs "ustwa010"
   host "10.1.32.146"
   key feb2b0030329a715ff744ddec0294f0ea4d04c13de703c1f
aaa server-group "default"
 auth-server Internal
 set role condition role value-of
aaa profile "default"
aaa authentication vpn "default"
   no cert-cn-lookup
aaa authentication vpn "default-iap"
   no cert-cn-lookup
aaa authentication vpn "default-rap"
aaa authentication mgmt
   server-group "xxx-tacacs-server-group"
   enable
aaa password-policy mgmt
control-plane-security
ap system-profile "default"
ap system-profile "emea-rap-ap-sys-profile"
   lms-ip 213.62.87.104
   bkup-lms-ip 217.33.23.200
   number_ipsec_retries 20
ap regulatory-domain-profile "default"
   country-code GB
   valid-11g-channel 1
   valid-11g-channel 6
   valid-11g-channel 11
   valid-11a-channel 36
   valid-11a-channel 40
   valid-11a-channel 44
   valid-11a-channel 48
   valid-11a-channel 52
   valid-11a-channel 56
   valid-11a-channel 60
   valid-11a-channel 64
   valid-11a-channel 100
   valid-11a-channel 104
   valid-11a-channel 108
   valid-11a-channel 112
   valid-11a-channel 116
   valid-11a-channel 120
   valid-11a-channel 124
   valid-11a-channel 128
   valid-11a-channel 132
   valid-11a-channel 136
   valid-11a-channel 140
   valid-11g-40mhz-channel-pair 1-5
   valid-11g-40mhz-channel-pair 7-11
   valid-11a-40mhz-channel-pair 36-40
   valid-11a-40mhz-channel-pair 44-48
   valid-11a-40mhz-channel-pair 52-56
   valid-11a-40mhz-channel-pair 60-64
   valid-11a-40mhz-channel-pair 100-104
   valid-11a-40mhz-channel-pair 108-112
   valid-11a-40mhz-channel-pair 116-120
   valid-11a-40mhz-channel-pair 124-128
   valid-11a-40mhz-channel-pair 132-136
ap wired-ap-profile "default"
ap enet-link-profile "default"
ap mesh-ht-ssid-profile "default"
ap lldp med-network-policy-profile "default"
ap mesh-cluster-profile "default"
ap lldp profile "default"
ap mesh-radio-profile "default"
ap wired-port-profile "default"
ids general-profile "default"
ids rate-thresholds-profile "default"
ids signature-profile "default"
ids impersonation-profile "default"
ids unauthorized-device-profile "default"
ids signature-matching-profile "default"
   signature "Deauth-Broadcast"
   signature "Disassoc-Broadcast"
ids dos-profile "default"
ids profile "default"
rf arm-profile "arm-maintain"
   assignment maintain
   no scanning
rf arm-profile "arm-scan"
rf arm-profile "default"
   no scanning
rf optimization-profile "default"
rf event-thresholds-profile "default"
rf am-scan-profile "default"
rf dot11a-radio-profile "802.11a-xxx-radio-profile"
   tx-power 127
   slb-mode radio
rf dot11a-radio-profile "default"
rf dot11a-radio-profile "rp-maintain-a"
rf dot11a-radio-profile "rp-monitor-a"
   mode am-mode
rf dot11a-radio-profile "rp-scan-a"
rf dot11g-radio-profile "default"
rf dot11g-radio-profile "rp-maintain-g"
rf dot11g-radio-profile "rp-monitor-g"
   mode am-mode
rf dot11g-radio-profile "rp-scan-g"
wlan handover-trigger-profile "default"
wlan rrm-ie-profile "default"
wlan bcn-rpt-req-profile "default"
wlan tsm-req-profile "default"
wlan voip-cac-profile "default"
wlan ht-ssid-profile "default"
wlan ht-ssid-profile "guest-htssid_prof"
wlan edca-parameters-profile station "default"
wlan edca-parameters-profile ap "default"
wlan dot11k-profile "default"
wlan ssid-profile "default"
wlan virtual-ap "default"
ap provisioning-profile "default"
rf arm-rf-domain-profile
   arm-rf-domain-key "c90d9172fa3158ef0f0618f6b8b5a8cc"
ap spectrum local-override
process monitor log
end
In your session access list "iaprole", you have a source NAT policy but no permit ip any any.
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
I've added the permit rule now but still not working.
A couple of things to mention
If I issue a "show user-table" on the controller, I see this:
(uktcnwc3) #show user-table
Users
    IP               MAC            Name              Role              Age(d:h:m)  Auth    VPN link      AP name      Roaming   Essid/Bssid/Phy                         Profile                            Forward mode  Type
2.2.2.191       00:00:00:00:00:00  00:0b:86:82:89:80  default-vpn-role  00:00:02    VPN     81.129.3.192  N/A        tunnel
Also, when following the configuration guide, it says to add the following:
host) (VPN Authentication Profile "default-iap") #server-group default
(host) (VPN Authentication Profile "default-iap") #default-role iaprole
On my controller, I don't have the option for "defualt-role iaprole".  These are my options
(uktcnwc3) (VPN Authentication Profile "default-iap") #?
cert-cn-lookup          Check certificate common name against AAA server.
                        Default is enabled.
clone                   Copy data from another VPN Authentication Profile
max-authentication-fa.. Maximum auth failures before user is blacklisted.
                        Range: 1-10. Default: 0.
no                      Delete Command
server-group            Name of server group
I'm running 6.1.3.8, but I thought that version of code supported this type of functionality.
Thanks for your help.
You need the PEF-V license to change that role.
Can you try replacing the0.0.0.0 route with one for the corporate network?
Sent from my iPhone
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
No luck,
I removed the 0.0.0.0 and replaced with
172.16.0.0 255.240.0.0 213.62.87.104
My DHCP server is 172.18.96.226
still not getting an IP address.
Can you configure a static IP on the client and test?  It must be something I'm missing here...if that doesn't work, please consider opening a support case.
Seth R. Fiermonti
Email: seth@hpe.com
Contributor I
Thanks for the taking the time to help me, I did try the static IP but that didn't help either.  Looks like I'll go down the TAC route.
Thanks again.
