Occasional Contributor I
Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs
Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105 IAPs platform, any ideas?
Re: Hi, I have a problem with MacOS devices, they are not connecting to the Network, and I have 105
What authentication method and encryption type are you using? Open / WPA2-PSK / WPA2-Enterprise?
Is this a new network or new issue with existing network?
What code are the IAPs running?
Tim Cappalli | Aruba Security
WPA2-PSK, This is a new network, but some of the MAC OS devices were working others not, now none is working, they are not even assosiating
- Are you using network assigned or virtual controller assigned ?
- Check the VLAN configure for that network
- Make sure that there's no issues with your DHCP server or the device providing IPs .
Thank you
Victor Fabian
Lead Mobility Architect
Hello, Im using Virtual Controller Assignned, The DHCP seems to be working fine since I have no issues with Windows devices, Android devices or even iOS devices. The issue it's only with MacOS devices, with a variety of versions.
Can you share the output of ?show tech-support??
