Occasional Contributor I
Hi, I see in the Visual RF Plan the 54mbps speed for ap 103 and can not use 300mbps does this AP use
Hi, I see in the Visual RF Plan the 54mbps speed for ap 103 and can not use 300mbps does this AP use only 54mbps and why the 300mbps is not present?
Re: Hi, I see in the Visual RF Plan the 54mbps speed for ap 103 and can not use 300mbps does this AP
emeikle,
Are you using the Windows-based version of RF plan or the Airwave version?  If so, which version.  Please also attach a screenshot of what you mean.
Thanks I use the Windows software
What did you set as the speed when you created the building?
Tim Cappalli | Aruba Security
300 Mbps, the problème is about the speed can not be set more than 54mbps ont the 103 ap provisionning if I use a 103H I can set it to 300. Anyway the result give no sens I manualy add the AP by looking on the coverage and signal strengt. The automatic provisionning is not realy reliable anyway!
