Hidden Instant SSID
I was doing some research in my Lab the other day and I've noticed that my Instant 105 appears to be broadcasting a hidden SSID using
wpa-psk-tkip ? Has anyone else seen this? I have 0 configuration relating to this and I can see this being broadcast from other controllers. Here's what I've pulled from the logs from both the Instant and the 620 controller.
Here is the SSID in question
iwconfig output for aruba000
aruba000  IEEE 802.11na  ESSID:"b73375eab4fa00c6290c67c905e2606"
Mode:Master  Frequency:5.54 GHz  Access Point: x:xx:xx:xx:xx:xx
Encryption key:EB22-7C1F-C903-DF36-C113-B162-087C-151D [2]   Security mode:restricted
I can see it being advertised when checking ARM neighbours on a nearby controller
AP Tree
Monitor Eth MAC    Radio  BSSID              ESSID                            RSSI  Dur  Cnt  Class        Clients  AP-name  Encryp          IBSS
d8:c7:c8:ce:c3:0c  1      x:xx:xx:xx:xx:xx  b73375eab4fa00c6290c67c905e2606  65    178  36   valid        0                 wpa-psk-tkip    no
The ap bss-table on the Instant does not show it broadcasting
Instant-105# show ap bss-table
Aruba AP BSS Table
bss                ess      port  ip           phy   type  ch/EIRP/max-EIRP  cur-cl  ap name      in-t(s)  tot-t
x:xx:xx:xx:xx:xx  weebox   ?/?   192.168.1.7  g-HT  ap    6/19/19           2       Instant-105  0        2d:2h:56m:51s
x:xx:xx:xx:xx:xx  weebox   ?/?   192.168.1.7  a-HT  ap    108+/24/24        2       Instant-105  0        2d:2h:56m:52s
x:xx:xx:xx:xx:xx  weexbox  ?/?   192.168.1.7  a-HT  ap    108+/24/24        0       Instant-105  0        2d:2h:56m:44s
Any ideas what this hidden SSID is?
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Re: Hidden Instant SSID
**bleep**....I should've searched Google better :D
https://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/Controller-lessWLANs/article-id/451
ACMA, ACMP, ACSA
Do you have mesh configured on either?
Hey, Mesh was not configured in either of them but Extended SSID was disabled. As soon as I re-enabled it the Mesh SSID was disabled :)
ACMA, ACMP, ACSA
