How can I turn AP to IAP
Hi All,
How can I upgrade AP to IAP, can I upgrade it using apboot menu ?
apboot> ?
? - alias for 'help'
boot - boot the OS image
clear - clear the OS image or other information
dhcp - invoke DHCP client to obtain IP/boot params
factory_reset - reset to factory defaults
help - print online help
mfginfo - show manufacturing info
osinfo - show the OS image version(s)
ping - send ICMP ECHO_REQUEST to network host
printenv - print environment variables
purgeenv - restore default environment variables
reset - Perform RESET of the CPU
saveenv - save environment variables to persistent storage
setenv - set environment variables
tftpboot - boot image via network using TFTP protocol
upgrade - upgrade the APBoot or OS image
version - display version
apboot>
Frequent Contributor II
Re: How can I turn AP to IAP
a RAP is not convertible to iAP but the other way it's possible.
If you found my post helpful, please give kudos!
Unit is originaly IAP-92, I want to turn back to IAP-92 again. There is nothing to do with RAP.
There should be a small hole on the bottom.  Stick a paper clip in there, power up, and wait until the power LED flashes quickly.  That will convert it back
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
use the purgeenv command the sequence would be as follows :
purgeenv
saveenv
boot
"There should be a small hole on the bottom.  Stick a paper clip in there, power up, and wait until the power LED flashes quickly.  That will convert it back"
I tried that, did not work.
call support!
Seth R. Fiermonti
Email: seth@hpe.com
Aruba
Try it again; make sure you hold the paperclip in there while powering up for at least 5 seconds before releasing th reset button.  See the diagram and instructions below.   If it doesn't work, call support as Seth suggests.
AMFX | ACCX | ACDX | ACMX
Super Contributor I
You can console in to the AP and reset the AP using the reset button at the same time, you can see the boot sequence and if it had cleared the config.
Normal Guy
If factory reset is not working, please share the following info from APBOOT:
Output of ?printenv'
Output of ?mfginfo?
Output of ?osinfo?
Also, another way of doing factory reset is the command ?factory_reset? in APBOOT.
However, I recommend against performing upgrade in APBOOT without clear instructions from Aruba.
Yan
