How do I assign multiple SSID's to more than 1 IAP?
I am new to Aruba, and have some high expectations of their system. I have set up a 3 IAP cluster, and have 5 SSID's.  I would like some SSID's to appear  on some IAP's but not others. It looks to me like using the "Zone" functionality, it would limit that SSID deployment to only hiding or displaying 1 SSID but not more than 1.  How do I accomplish this task?
Valued Contributor II
Re: How do I assign multiple SSID's to more than 1 IAP?
Hi Friend,
It is possible,
You have to specify the same zone name in multiple SSIDs and map that zone name to IAP which you want to broadcast those SSIDs.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
Why do you have 5 SSIDs? That is a lot of management traffic.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
My SSID's They do different things.  Most IAP's just have access to the public and private SSID's but I have set up a couple that are WPA2 PSK only for specific purposes.  I would like to deploy those to singular AP's as needed.
Can I have more than one zone name applied to an SSID?  What you suggested won't work for what I need.
Hi, I also have the same question. I have 4 SSID's and 3 IAP.
Example:
Customer office have 4 SSID's which are "Guest", "Employee full access", "Employee intranet access" and "VIP". 3 Different location of IAP.
Location A only need SSID "VIP" and "Employee full access"
Location B need "VIP", "Guest" and "Employee full access"
Location C need "VIP", "Employee intranet access" and "Employee full access"
From the IAP 4.1.1 .x user guide
ACDX #420 | ACCA
