How do I generate a report in Airwave for Top Clients By Total Traffic?
How do I generate a report in Airwave for Top Clients By Total Traffic? I'm running version 8.0.6.3.
Thank you
Re: How do I generate a report in Airwave for Top Clients By Total Traffic?
You would create a new report definition with the type of "Client Session".   Make sure you set the "Include details about every client" parameter to Yes.  Save and Run it for the period of time you are interested in.
Hi Colin,
I have created a new report definition but when I Save and Run I'm not getting the email. It's also not showing under the Generated reports.
Kindly assist.
It should show up under generated.
Got it thanks
Spoiler
