How do I mount ap-ant-15 to shoot wifi signal to exterior structure from main building?
MVP
Re: How do I mount ap-ant-15 to shoot wifi signal to exterior structure from main building?
From the spec-sheet here: (http://www.arubanetworks.com/pdf/products/ap-ant-15_ss.pdf)
It looks like you screw it to the side of one building pointed more-or-less toward the other.
Isn't 120degrees a little wide for a poit to point link? Or are you hoping to serve mobile clients in the region between buildings as well?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
That is what the sales rep suggested.
Sent from my Verizon Wireless 4G LTE smartphone
Valued Contributor I
Depending on what AP you are connecting to and distance you might look at an antenna with higher gain such as the ANT-2x2-5314.  This is a 30deg antenna and 14dBi gain.  This has a narrow focus so it does not "hear" as much noise from the environment. Keep the connector types in mind.  Outdoor antennas will have Type-N connectors, as do our outdoor APs where indoor APs use RP-SMA connectors so you need an adaptor.
For a complete list of our supported antennas please click ~here~ .  This matrix shows a photo of the antenna, gain, antenna pattern, and the connector type.
