How do I set the MTU on an IAP-134? I do not have a controller.
Users are experiencing up to 36% packet loss, especially while connected to VPN jounos. Also majority or users are Mac users.
Super Contributor II
Re: How do I set the MTU on an IAP-134? I do not have a controller.
Which OS you are using ?
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
I am using 6.2.1.0-3.3
I am afraid you can ONLY set the MTU size while configuring tunnel. Other expert may guide you.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
