Moderator
How do Instant APs work?
Hello
A customer of ours has asked us about the protocols behind Instant APs and their virtual controller technology.
I guess it works more or less like VRRP with no preemption and the same priority for all APs for the master AP election. For control traffic, i suppose it still uses PAPI tunnels but I would like to give our customer a more precise answer. Are there any tecnhnical notes addressing virtual controller technology?
Regards
Samuel
P.S. I've already seen the tech notes on the main webpage, but I'm afraid I need a bit more detail.
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Moderator
Re: How do Instant APs work?
The virtual controller or master is elected  using an election process that involves all IAPs in the group. If there is a contention, the IAP with the highest uptime will win.
There are no tunnels built for control traffic. The IAPs communicate using layer 2 broadcast and this is very lightweight.
There are additional details that can't be shared externally, but if there are specific questions or issues that the customer is concerned about, I will be happy to discuss those.
Shashi
Moderator
Hello
We've been capturing traffic in one of our customers network and have found out the following:
  • Control traffic (master AP election) between APs is done using PAPI (or at least it is UDP 8112) protocol.
  • The configuration is passed from the master AP to the rest via HTTP (plain text)
Samuel Pérez
So the IAP works like the APs with the controller with bridge mode right?
Alternetworks Corp
