How do i create a rule for IAP's to prevent users from issuing DCHP?
I have an issue where a client is issuing DHCP leases. With controller based systems I alway implement a firewall rule as standard to prevent users from issuing udp port 67. How do I do the same on an IAP installation?
Thank you in advance..
Regular Contributor II
Re: How do i create a rule for IAP's to prevent users from issuing DCHP?
rule type: access control
Action: deny
service: custom
protocol: udp
port : 68/67
to all destination
Valued Contributor II
We should deny UDP 68 traffic from a user to any destination. It is simple, if you want to allow a client to get an IP address, allow UDP 67 traffic from the client, if you want to stop the client to Assign/Renew the IP, Deny ( Stop) UDP 68 traffic from the Client.
Hope you got more clarity on this.
Please feel free for any further clarity on this.
Cheers,
Venu Puduchery,
Hi Venu,
Thank you for your response.
On a controller based system the rule can be created either by the GUI or terminal:
user any udp 68 deny
Where is the rule created on Instant APs?
Under security, you can configure the roles and add firewall policies.
http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/Roles_and_policies/ConfUserRole.htm
Tim
Tim Cappalli | Aruba Security
Thank you for the advice and support!
Kind regards
