Contributor II
How do i modify an SSID?
I recently set up a new IAP215 and named the Network "Test" to configure it and to learn all about it.
I now want to change the SSID to the finished network name, however, whenever i click on Edit in Aruba Instant, it does not allow the modifcation of the SSID.
Is this not possible, or am i looking in the wrong place?
Thanks.
Re: How do i modify an SSID?
That depends what version of code you are on.  In the 4.2 release, this (finally) allows you to change the essid.  You will however still be stuck with the profile name of 'Test'.
I would suggest recreating with the name you want to make it tidy.
ACCP, ACCX #817, ACMP, ACMX #294
Contributor II
I'm assuming the 4.2 is the instant os?
It was installed yesterday and I installed the latest firmware for the AP.
Edit the ssid and click on Advanced options, and it is in the bottom right.
Contributor II
I don't have that option on advanced, however, I've just discovered that my AP isn't set to 'standalone' mode.
Should I convert it as it is the only AP I have in the house?
I'm also guessing that this may be the reason why some options are not available
Contributor II
That didnt seem to change anything either!
This is what i have under advanced...
what is the exact version you are running?
Contributor II
Im running...
6.4.2.6-4.1.1.11_52666
Ah ok.  That is 4.1 code, which is the second part of the version.  Try upgrading to 6.4.3.1-4.2.0.3.
Contributor II
Thanks Michael, however, where do i find that version?
I used the automatic way on the AP, and it says im up to date?
