How is work AP when it detect a dynamic load balancing trigger?
When the AP detect a trigger from dynamic load balancing, it try to move the client to another AP. AP try to deauth the client, for client will been moved. My question is, how ap deauthentication client? Maybe AP sends to client error code 17 (this error code means AP is too busy)?
I attached the report.
